Well following on from my previous thread about the engine not running as it should, i have decided to go down the new engine route.
It is a 2000 X 1.4 8V (Engine Code - AKK iirc) currently.
I am looking for a replacement engine for it, but need advice before looking for what i can get.
If i was to find a 1.4 16v engine, would it be compatible with my existing 8V engine loom? There are plenty of Polos out there that i could get an engine from. Or would i need Engine Loom too aswell as engine? There is also the 1.6...??
Another 8V is also another option and it would make things more straight forward, so this is probably first choice. What other VAGS have the same 8V engine (AKK)??
Anyone know of any engines available in Yorkshire area?
I realise this is a Cupra forum and this type of engine doesn't really apply, but seen as your all SEAT enthusiasts, i thought it would be worth a shot... I cannot do a 20VT conversion either, as the car is only a run around and will most likely end up in the hands of my little brother when he turns 17...
Any help would be brilliant. If you have an engine i may be interested in, please PM me.
