To quote Fords tech release....
The VXT 75 transmission used in the Galaxy is based on the well-known MTX 75 transmission. The differences between the MTX 75 transmission are listed below:
-- Transmission-end housing section modified for attachment of the roll resistor and hydraulic mounting and for the new gearshift mechanism. The fluid drain plug is repositioned.
-- Internal gearshift mechanism with new flange housing because of cable actuation.
-- Both housing sections are modified in the area of the final drive assembly.
-- Double synchronisation for 1st, 2nd and 3rd gears.
-- Modified output shaft
inion forms a unit with the shaft (removable on MTX 75).3rd and 4th gear wheels pressed on (unified with shaft on MTX 75). This gives rise to changes in the procedure for dismantling and reassembling.
-- Changed preloadings for determining shims for input shaft, output shaft and differential.
-- Differential reinforced.
-- Increased weight.
-- Reduced fluid capacity.
-- Slave cylinder for hydraulic clutch actuation is the same for all engine variants (green sleeve).
