Just wondered what was involved in fitting a 6 speed bo to the ibiza. What mounts do you need, do they just bolt in? do you use the original driveshafts? what about the shift mechanism and which box do you need?
I had 6spd quaife synchro in my mk4 golf.. hated it
I had quaife 6spd dog box in my ibiza.. hated it
had my 02J std box until it expired (2nd gear teeth ripped off).. loved it apart from the synchro's baulking at high rpm changes (7800rpm)
My 02A replacement was slightly shorter geared than the 02J was, but otherwise was fine. (until that too broke recently, 5th gear teeth ripped off)
The quaife 6spd synchro *should* be ok, but they use the VW synchro rings which dont like high rpm changes. (weak point IMHO) - otherwise should be a strong box unless the selector mech falls apart allowing you to engage more than one gear at once. *cough* Quaife *cough*
6spd just means more gear changes... 5spd suits the turbo motor torque, with std 02J 20VT ratio of 3rd gear being immence! 30mph-120mph single gear on BT
i know this is the other end of the scale but my mate has just put a 106 diesel box in his gti to make acceleration and what not better. its crap at top end but hes into his 1/4 mile etc. just thought i would mention it...
