'57 FR TDI - Traction light...
AwesomeAl
Sales @ Awesome
Sep 17, 2008
438
NorthWest
www.awesome-gti.co.uk
My mum has been out for a drive in her recently purchased Ibiza FR-TDI today and noticed that when the traction control kicks in, Instead of flickering on and off, It stays on until the engine is turned off and on again. At least I think its the traction control light anyway... The one which is a little yellow car with a pair of S's coming off the bottom of it...
As far as the manual is concerned the light shouldn't stay on...
Anyone else had this problem ?
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
ive herd when a brake light bulb goes it can cause this. so might be worth checking you brake lights
st10587
Oct 4, 2007
3,669
Hindhead
Hmm, No that's usually the Glowplug light that comes on when the brake pedal switch is goosed.
Have just checked all the bulbs and they are all working perfectly.
on my friends LCR the traction control light came on when the airmass meter went. or it could be a faulty/dirty ABS sensor as the car uses these to work out which wheel is spinning
AwesomeAl
Sales @ Awesome
Sep 17, 2008
438
NorthWest
Strange, If anything the Engine/Emissions light should come on for that but I've seen stranger things happen :)
Possibly an ABS sensor... Need to get it plugged into Vagcom but can't get the car in to work until Friday as my mum needs it tomorrow and I'm off on Thursday.
AwesomeAl
Sales @ Awesome
Sep 17, 2008
438
NorthWest
^ Its the wavy car symbol out of that lot btw...
Breezapom
mk4 ibiza fr 20vt
Jan 12, 2006
608
Hampshire
yeah that is the tc icon and no its not ment to stay on as you have said get it hooked up to vag.com when its showing and see what it says it couldnt be somthing simple like a dodgy tc button?
AwesomeAl
Sales @ Awesome
Sep 17, 2008
438
NorthWest
It's a bit of an odd one, You can be driving round for ages, and It won't actually come on unless there is any wheel-spin.
If one of the wheels does spin, it seems to come on but not go off...
Will have to get it on Vagcom either Friday or Saturday.
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Dirty or faulty wheel rotation sensor/encoder. BTW the prefacelift has a different icon for the traction control, It looks like an orange triangle IIRC.
george130
157
Norfolk
Could be a faulty connection to the alternator...
Look here:
http://www.seatcupra.net/forums/showthread.php?t=173256
which has a link to here:
http://www.seatcupra.net/forums/showthread.php?t=162855
muddyboots said:
There's a connector block mounted on the front of the gearbox. The alternator wiring runs through this, and it's common for a wire to break off at the connector (happens on Ibiza and Fabia TDIs). The ESP module relies on a "load" signal from the alternator (not sure why) and the module will disable itself after 10 mins if it can't see the load signal.
You won't see if from above though, you'll have to get the undertray off and fiddle around from underneath.
I just soldered a link wire in to bypass the connector, problem solved. Can't see there will be any reason for the connector to ever be taken apart, suspect it's just there to aid assembly of the loom in the factory.
AwesomeAl
Sales @ Awesome
Sep 17, 2008
438
NorthWest
Hmm George that might make a bit of sense...
I have noticed that the headlights/dashlights dim quite a lot when you turn the steering wheel... almost as if the alternator is not powerful enough for the car?
It's probably worth noting again at this point that the car has done less than 17,000 miles and is little more than a year old !
george130
157
Norfolk
The headlight dimming thing is quite common, as the power steering unit draws a lot of current :) Same thing happens for me as well with the electric windows lol.
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
might be worth checking the air flow meter also, as this is where the signal is sent to limit the car from accelerating when the traction is lost. if you unplug the afm the traction light will stay on.
markthommo_84
246
England
happened to me a few weeks back. came on randomly whilst driving down a dual carriageway - no wheelspin or cause for it to come on but it stayed on til i turned engine off.
it was what George said - connection to the alternator. broken wire somewhere causing connection to break.
Slippery_Stu
72
I had the problem that George130 referenced above, dropped off the undertray and spotted it immediately.
A strip of wire, couple of inline crimps and some pliers and it was done in a matter of seconds.
Certainly worth a look.
AwesomeAl
Sales @ Awesome
Sep 17, 2008
438
NorthWest
As suspected it was the Connector plug held on by a bracket to the gearbox. Took me a couple of minutes after getting the undertray off to find it. It was located right above one of the radiator hoses. A Two wire connector block in which BOTH wires had broken off.
Here you can see the connector in its "home" position with no wires attached on one side.
Here's the culprit! Two bare un-connected wires!
As you can see by the state of the connector the wires had quite literally clean snapped off!
I found myself One blue and white and a light blue length of wire Just enough to extend the loom so that lateral movement would not cause the problem again. I removed the wiring plug and used 4x standard red butt connectors to join the loom extension making sure the connect wires were connected to each other.
I then re-loomed the wires together using black electrical tape and used a bit of orange silicone rubber to stop the metal bracket chafing on the new loom. Enough slack was left on the side that had broken for any lateral movement not to cause the same problem.
Hopefully this rough guide to how I fixed mine with the photos will help some of you guys out in the future :)
Would like to give a big thank you to everyone who has helped out in this matter!
Cheers guys :)
