4 fault codes
Jamesymac
16795 P0411 Sec.Air Inj.Sys. Incorrect Flow Detected
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
17524 P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
17511 P1103 O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low #
any help with these would be great
d3lboy
136
I had the bottom two codes come up on mine a while ago and i changed both sensors in exhaust and that sorted it!! You got any lack of power?
Sent from my GT-I9100 using Tapatalk 2
Jamesymac
no lack of power that i have noticed. going to get new sensors tomoz to sort the two at bottom of list
d3lboy
136
Sounds like mine i had no running issues. Jus had light come on while driving on motorway and replaced the two sensors which cleared the light
d3lboy
136
might be worth checkin over your vac lines and DV!!
mty12345
3,907
538
bristol
I get the first one every now and again about the secondary air system, i've noticed once in a while it won't come on at cold start up. Seems to throw that code when it happens, but 99.9% of the time it works fine so if yours is the same the i shouldn't worry about it tbh mate. Other codes are much more of an issue.I've had the second one come up on disconnecting and reconnecting the battery. 3rd and 4th are the sensor in the exhaust http://wiki.ross-tech.com/wiki/index.php/17524/P1116/004374
