Hi Guys;
I have just vagcommed my LCR after having some limp-mode issues every once in a while. The fault codes are:
16486 P0102 Mass or Volume Air Flow Circ Low Input
17863 P1455 Exhaust gas temperature sensor 1 range/performance
17963 P1555 Charge Pressure Upper Limit exceeded
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
Can anyone tell me possible problems; things to change etc? and how do I reset the codes to see if they come back again? I think the 17963 will have been immediately after my remap when I was seeing spikes of 28psi boost - since then I have replaced the n75 and installed a MBC to run in parallel with the n75 to limit spikes to 24psi (suggested on mkiv forums).
Any help would be great.
Dan
Dan
