312mm Help needed.
SportCider
Gone to fit my 312mm's this morning, but noticed that the bolt that holds the original caliper to the original carrier is far too short to use on the 312s.
Should i have a different longer bolt for the 312s? sure i read somewhere you can re-use the original bolts.
Any help appreciated.
SportCider
found out i need some M12 high tensile 40mm bolts for this.
SportCider
it wasnt the carrier bolts. Its the bolts that attach the caliper to the carrier, im guessing most peoples kits came with these whereas mine havent!
Don't suppose anybody can help out with a specific part number?
techie
Skoda Techie
Mar 22, 2003
5,438
Worcs
If you have 312mm calipers and carriers then there arent any bolts holding the caliper to the carrier only two 7mm allen key sliders which are not fitted to your standard brakes.
SportCider
Thats what i'll be needing then. Do you know of a part number for them?
