3 time Beep when cornering hard...
zukit
Strange thing in my 130 sport - I get beeped when ever I corner hard and some times the brake indicator flashes for a very short time (while beeping).
Any idea...:confused:
killbill
25
Athens,Greece
Τhe beep sounds because the sensor "thinks" that the brake fluid level is low . But when you check the level , you will find out that you are ok . Just ignore the beep and keep turning !!
Mr Max
and the fun part is, when you go to your seat dealer and they plug it in they can tell you've been cornering hard!! :D (well according to my local stealer)
dozza.13
PS3 Tag - Dozza1979
Jun 30, 2006
1,082
Grimsby
Mite be worth checking the wear on your pads too, if your brakes fluid is getting low it mite be due to excessive pad wear, or worse case scenario you could have a brake fluid leak, which would obviously be very very bad!!!
