3 Door Rear Dooor Card Removal
Ric 2001
Need an ID-ten-T form
Have read the sticky about door card removal, but just wanted to clarify that it’s only the 2 screws behind the rear seats that are holding the door card on + some plastic clips.
Just asking because it seemed to be stuck there really well. Is it just the usual brute strength required and pray that you don’t break the clips?
Also think its the B pillar trim, the trim that runs from under the door and half way up the door, is that also pull and pray.
gazjones
b piller has screws holding it in place under the rear pannel but clips at the top, an only clips holding rear card in place and those two screws
