It helps if you have a vice to hold the pump.
You also need a deep 18mm socket which I didnt have. Had to improvise with a normal socket and pipe wrench around it.
Its a doddle if you have the right tools.
Removing the pump can be quite tricky if your fuel pump has the banjo fitting instead of the hose.
Take your time, keep everything clean and just follow the instructions.
