20mm spacers
rikwheeler
131
Lincoln
www.rikwheeler.com
I've searched on the forum and a lot of people go for 15mm back and 10mm front.
Got some 10mm for the front but wondered if anyone has fitted 20mm on the back?
Has someone got a pic of them on?
big eck
3,976
Falkirk, Scotland
I would like to see pics of this as well.
I fitted 20mm rear spacers to my old Ibiza cupra but got rubbing, looked good tho and transformed the cars handling.
Is it the same kind of deal with the much bigger Leon???
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
I heard 20mm rub on the inner arches which is why I went for 15mm's. Mine is very close when fully loaded, wouldn't like to try the extra 5mm tbh!!
BlackIce
Where the hell do you get the extended bolts from? Mine has 5mm spacers on and I had to special order 33mm long bolts!
westoncraig
reviver of old threads :)
Aug 7, 2005
826
weston-SUPER-mare
infact they are next to the blue box on the top shelf of my garage in the sig....
basemanuk
scooby to leon
Sep 30, 2008
227
chelmsford
is there alot of difference in fitting the spacers! if you have 10m front and 15m at the back do you need longer bolts on all
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
If there the type of spacers that bolt to the car then the wheels bolt to the spacer then you don't need longer bolts.
If there just normal spacers you need longer bolts on any spacer thicker than 5mm
