Shytot
141
Hi Yall
I was cleaning the parts relating to the DV and I noticed that the valve above the vac at the top left of the engine has exactly the same code as the N75 F I have fitted? Does the Ibiza have 2 of the same valve? I thought it was an N2119 or something, can anyone confirm?:shrug:
Ok, my explanations suck! Sorry about that gents.
The DV has a pipe coming out of the top, this goes to a valve, I have 2 of these valves, one of which is attached to 2 little rubber holders on the top left of the engine bay as you open the bonnet, is that an N112 valve?
Yes. :)
You N75 has three connections. One to the turbo actuator, one to the charge pipe coming out of the turbo and one on the turbo inlet pipe.
Hi DPJ
Thanks for the replies. I was just a bit freaked out to see the same valve ID twice!
Have a great weekend
