2.1T and 2.0T
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
im currently looking into going 1.9 on my motor but im now thinking of the 2.1 ive seen done on a TT
or maybe 2.0 just for abit more strength
has anyone had any experience with either or knows anything i may want to know?
cheers in advance
HoocH
minimivic
Drives a 16v mini
Aug 26, 2006
189
Dorset
www.btinternet.com
the larger displacement engine will be good for torque and low down power. It will also spool the turbo faster.
But is it really nessesary? with 300+HP and FWD you'l have enough fun.
If I were to do this I'd do a 20/20 motor (2.0l 20v) using a diesel block and crank (I think thats what I read somewhere). But personally I'm raising the rev limit a bit and using the bigger gt30 to get more power. Hopefully that works out for me.
myk3
Newbie
Dec 16, 2005
304
i would just bore to 1.9 as i have done, then you dont play with how the car will rev, with larger crank it wont feel as revvy, but of course allot more power and torque
simch
Newbie
Apr 12, 2004
33
I have seen one of those TSR ones being mapped with an IHI and it was a beast!
In an octy, was running over 1bar of boost at 2500 revs! Real grunty motor by all accounts. expensive compared to a 1.9 though...
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
Dans A3 quattro runs 2ltr,eurospec crank. which is actually lighter than 1.8T one.
traction!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
how deep is your budget.
82.5mm or 83mm bore on eurospec's crank would get ya the ability to run big turbo without the lag....
then there's the simple question of traction.
:whistle:
h17och
Sep 1, 2005
3,504
Dunstabubble
how deep does the budget need to be?
how much would just 1.9 cost?
how much would euro spec crank with with pistons trimmings cost?
just guesstimate
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
weisco pistons recon on £300-£400 a set
boring @ m/c shop £70
cranks here>
Part Number Engine Type Stroke Description Price
EFC 105 101 B864 028, 048, 058 86.4mm Old Style Short Nose and Trigger Wheel. 13.1kg $1,095
EFC 105 101 B928 028, 048, 058 92.8mm Old Style Short Nose and Trigger Wheel. 13.1kg $1,095
EFC 105 101 C955 038, 06A, 06B 95.5mm New Style Long Nose and Trigger Wheel. 13.1kg $1,243
EFC 105 101 SB 928 028, 048, 058 92.8mm Old Style Short Nose and Trigger Wheel, Super Light. 12.5kg $1,295
EFC 105 101 SB 955 028, 048, 058 95.5mm Old Style Short Nose and Trigger Wheel, Super Light. 12.5kg $1,295
EFC 105 101 SB 100 028, 048, 058 100.0mm Old Style Short Nose and Trigger Wheel, Super Light. 12.5kg $1,295
EFC 105 101 SC 864 038, 06A, 06B 86.4mm New Style Long Nose and Trigger Wheel, Super Light. 12.5kg $1,243
EFC 105 101 SC 928 038, 06A, 06B 92.8mm New Style Long Nose and Trigger Wheel, Super Light 12.5kg $1,295
EFC 105 101 SC 955 038, 06A, 06B 95.5mm New Style Long Nose and Trigger Wheel, Super Light. 12.5kg $1,295
EFC 105 101 SC 100 038, 06A, 06B 100.0mm New Style Long Nose and Trigger Wheel, Super Light. 12.5kg $1,295
GOLF GTTi
71
Glasgow
Bill I spoke with James (I think ) from JBS at inters, he said that he didn't advise going 2.0L "as it just didn't produce the power" was his words, "just go to 83.5mm bore" was his advice??? :shrug: I thought that going 82.5mm with an 8.5:1CR and the 92.8mm EuroSpec crank would have made good long term sense as in my mind it would make the engine better for everyday use due to the improved bottom end torque and minimise lag allowing for a reasonable sized turbo to be used on a day-to-day basis...... Does that make sense to your way of thinking?? :help: You could have knocked me over with a feather when he more or less said that it was cr@p and it wouldn't do as I expected.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Well we can all have opinions. :)
2ltr will produce significant more torque and allow earlier spool on 'bigger' turbo's. This has been proven by Jabba some time ago on a mk4 golf (agu) on just a VF22, which it max'd out by 4K rpm from increased airflow from the increased capacity. 82.5mm bore did'nt do this alone.
83.5mm bore is extreme and leaves very little wall thickness between bores for head gasket sealing.. I went 83mm and thats "close" to too much imho.
2ltr is more expensive but more stroke will allow more airflow, and eurospecs crank is lighter than 1.8t so revs might not be as limiting as you think.
would love to see Dans A3 up and running on his 2ltr motor..
myk3
Newbie
Dec 16, 2005
304
custom je 83mm pistons cost around 400, then bore costs around 90 quid from RPM
so to go 1.9 is around 100 or so more than the stock 1.8.
if you want 2.0 then you need the 92.8mm crank and also request the pistons to have the pin moved up 3.2mm. so you will need an extra 500 or so for the crank.
then the rest is labour, unless you DIY
oh and remeber your 20mm scat rods ;)
h17och
Sep 1, 2005
3,504
Dunstabubble
hmm, im liking the sound of 2.0l and eurospec crank! not as expensive as i thought!
watch this space
HoocH
caney
600
golf gti! someone else at inters said to me the same thing as you were told about going 2ltr/2.1! james told him that a 1.9 is as much as you need to go? jbs seem happy enough to fit a twin scroll turbo set up on a 2.1 TT though;)
