2.0 16v intermittant misfire
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Picked up a little gremlin in the past few weeks
Started off with it missing at 3k rpm - warmed up and then dissapeared - perfectly fine after that.
Did a not so clever thing by jetting the engine bay out last monday to suss out an oilleak :doh: ran like crap upto 4k rpm (no ****) - dryed out after 10 mins - ran fine thereafter.
Jumped in it tonight after work, and it started missing @ idle, 2.5k, 4k but pulled like it should - warmed up and all was fine :think:
Its done 53k and apart from the ovbious service items is there anything else I should be looking out for? did a search which throwed up it could be a multitude of expensive sensors and I've not got Vag-Com.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
locate teh engine speed sensor connector & get some WD40 in it mate.
and all the other connectors you can be bothered to do as well
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Forgot to ask where that is, the leads & dizzy cap look like original from factory and the rotorarm is glued in.
I'm praying this isn't a legacy of my fumbeld change @ Brands.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
rotor arm is easy to break off - just take it easy with that (£6 for a new one from VW main stealer)
Engine speed sensor is behind the front engine mount, so play follow the wire
WeeJase
pert
Jun 2, 2001
8,595
fiddly little sensor that used to live on the side of the air box(can you tell i've forgotten what its called).
F2 Stu
I. Am. Legend.
Oct 4, 2001
5,577
Crawley, UK
Played follow the wire and it took me to the g'box:shrug:
Anyway ran fine from cold this morning & this evening.
WD'd all the connections I could get to, some of them had moisture in them - no rubberseals
I'll whack new plugs, leads rotor arm & dizzycap at the weekend
Jason, Ive left that sensor disconnected after I did the cam belt and ran no different bizarre.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
noticed on mine last time the engine speed sensor looked easier to get to with the oil filter off - easier but still not easy
was on a ramp though :p
as for follow the wire - iirc the 3 2 pin connectors on the end of the engine (in front of the big round main one) 2 are knock sensors and other is engine speed
brown/grey/black - cant remeber which is which i THINK the knock sensors were grey/black
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I did mine with the front end off & the engine mount removed :D
