16'' x 7j 4x100 et35 over brembos
Dec 13, 2006
724
Ashford, Middx
Depends on the caliper clearance of the wheel mate.
Image stolen from Bill
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
depends on spoke design
I used to run 7x16 Speedline 5 spokes which cleared with 0.75mm clearance. ET35, 7x16 rims
its all in the spoke design.
Some compo MO's with curved spoke design clear fine also in 7x16 ET35
mitch2028
76
theyve got a very curved spoke design so i might just risk it.
bill will i have any more difference in clearance if its a brake kit purchased from you? got reciept for it if you need reference to which kit
724
Ashford, Middx
The Brembo kit from Bill requires 38mm caliper clearance. What wheels you looking at getting? Cant you get them measured to double check they fit first?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
as said 38mm is the caliper clearance on my kit which is same offset as ibiza cupra-r requirement.
cuprachrissy
alright guys sorry for bringing up an old thread but thought it'd be better than writing up a new one, are these wheels be the right et for my car?? got standard brakes (maybe getting brembos v.v soon). should be picking up these wheels tonight, absolute bargain, diamond cutted :D
Set of 4 BBS RX211
7jz16
4x100 stud pattern
polished lip and black sides of spoke
but polished faces
look absolutely mint
et 42
hub 57.1
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
15mm should be enough on the rear yes.
front with 8 maybe.
You can easily pull off 20mm on the rear as well I would imagine.
but its really guessing without physically putting the wheels under the car. I'm affraid I don;t know exactly what fits and what doesn't.
cuprachrissy
Set of 4 BBS RX211
7jz16
4x100 stud pattern
but polished faces
et 42
hub 57.1
has anyone had any experience fitting this "ET" on there wheels before? i know reuvers thought i needed spacers but dioes anyone know for definate? thanks :)
Dec 13, 2006
724
Ashford, Middx
You'll definately want spacers at the back and as reuvers said 15mm or 20mm wouldnt be a problem.
Isn't your car off the road at the minute? Could you not trial fit the wheels and then see how much space you have etc etc before buying the spacers.
