Aug 11, 2024
I have a 2013 Seat Ibiza and would like to install ambient lighting in all four doors. Unfortunately, I discovered that there is no 12V power supply available at the doors. Since it's a closed system with pin connectors and the CAN bus doesn't provide a constant 12V to the doors, I can't simply tap into a power source.
I would like to know if you can assist me with this and what the cost would be to run the necessary wiring and from where i can get it through cause the door has not a opening for it
