12 or 8 Pin?
kstandsteve
I have been looking for a Dension Ipod kit for my mk1 Leon Cupra.
All the ones I have found (VW/Seat) have a 12 pin connector to the back of the headunit.
From what I can gather reading thru previous posts my Aura HU has an 8 pin connector.
Question is do I need the 8 pin or can the 12 pin be made to work?
Steve.
Nov 27, 2006
1,204
www.cardomain.com
I suspect the 12pin version will be a rectangular plug that connects to the end of the changer lead (as opposed to the back of the headunit)
If you're getting one online, go for the one that's recommended - cos I don't know much about compatability - but if you have the changer lead into the glovebox already and you're buying from somewhere where you could easily return it, try a 12pin version.
I've used the Soundlinks adapters in almost every version & configuration and they all tend to work with the Aura HU
kstandsteve
Cheers for that - never thought about it connecting at changer end?
Not heard of the Soundlinks adapters - will go and take a look.
kstandsteve
Done some more research on this.
From what I can make out my car (2003 model) will need the 8 pin connector. The 12 pin was used on later VAG cars.
Anyone confirm this?
