rudey
i have a seat alhambra p reg , 2 weeks ago driving back from london it cut out sudenly ( almost like fuel had run out, but it had fuel in it ) cranked it over would not start ( glow plug lights come on and go out etc..)
got recovered (after 2.30hr wait with rac )
after it got home next day
stripped of the fuel filter , filled new filter with fuel tried to start same problem ,brought an inline hand pump to prime fuel into high pressure fuel pump, still not starting
cracked of injector nuts and no fuel was coming through from high pressure fuel pump,
i then replaced timing belt and high pressure fuel pump , now fuel is coming through but not under pressure ?
, timed it back up -replaced water pumps ( it was noisy ) re-greased the idler pulley etc...
not starting
i have used my m8ts solus and vag software and there is NO codes present !!! after it had broken down there were no codes present either
it seems like a mechanic fault
, it will run on easy start , i am thinking about towing it as i think that the high pressure pump is not turing over fast enough , is there anything else i can do ???
as i am at the end of my tether
ok update , just towed around block 5 times no smoke from exhaust , and vehicle trying to run ... but still no good sad.gif
not starting
