1.8T FR - Turbo Gasket problems
nickd
This post is for my mate as he needs advice on a new part.
His FR is currently running Revo stage 2, however he's been having problems with his turbo gasket, since the remap, he's already had a new gasket under his warrenty, however, it seems like its on its way out again. :doh:
Does anyone know if there is an uprated part for this as it sounds terrible, as its consently blowing.
Thanks guys!
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
could also be due to worn engine mounts that have loosened up and the movement of the engine is sending unwanted flexes in all the joints causing the bolts to eventually rattle loose im in the process of getting some custom made engine mounts from vibra technics to stop me getting my turbo gaskets replaced for the 5th FCUKIN TIME :cry:
gazjones
had this problem with mine after 5k miles on stage one revo but after it was fixed did 15k miles on stage two revo and no probs and that was with less flexible dp as well. and there isnt any uprated parts from seat of vw for it.
Yella Beeza
Now which way?
Jun 4, 2007
497
Edinburgh
Yes, that's what I thought but can't put two nuts on if it's bolts. Unless there are nuts on the end of the bolt, instead of the bolt just screwing in.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Do you want me to post the photo of my 3 month old bolts seized into my K03S and snapped off? :scary:
Anti-seize is the only thing to put on those three bolts (and I had it). If they are coming lose, they weren't torqued up properly.
