thechunk
Should be an easy one, can someone give me a quick run down of what's included in the 60k service please?
Cheers,
Alan.
Renew Oil
Renew Oil filter
Renew fuel filter
Renew air filter element
Renew spark plugs
Renew pollen filter element
Check brake pad thickness and renew if necessary
Check manual transmission oil level
Check underbody protection for damage
Check exhaust emissions
Renew auxiliary drive belts
Renew timing belt
Check and adjust clutch pedal freeplay where applicable
Reset service interval display
Hi,
Cam belts are advised at 80,000 miles, plugs, fuel and air filters are due every 40,000 miles.
Pollen filters every 20,000 miles. oil and filter and general check over every 10,000 miles or 12 months. brakefluid change every 24 months.
Jochen.
Hi,
Are you sure about that? That seems quite high.... I got the service info from my Haynes for my Ibiza, but the Ibiza and Toledo uses the same engines... In the Haynes they advise you to change the cambelt at 40k if the car is used mainly for short journeys...
P.S. Spark plugs should be changed at 40k and are advised to be changed again at 60k, but they should be ok untill 80k...
EDIT: Ah, i've just noticed this section is for mk1 and mk2 Toledos, so if it's a mk2 then they will use different engines...
There isn't a Haynes for mk2 Toledo but I've got the Golf/Bora manual. In there it says check but not necessarily replace at 60k. I may just give it a check over.
Hi Anyone Know Where The Fuel Filter Is In The Seat Toledo 1.6sr 99 New Shape
