1.4 TSi Problems...
DeanzVrs
87
South Yorkshire
Looking at buying the Cupra MK5 1.4TSi and after reading all night about misfiring etc it's got me wondering....is this just when people have mapped them? or just in general? any common problems with this engine? cos i thought they were supposed to be top like.
I have no interest in mapping it once i get it, 180BHP is plenty quick.
cheers
Apr 14, 2011
968
I've read that it even happens in standard form to some people who's car hadn't even seem a map and that's why most got rid of em
adamb87
cupra gone :(
Feb 13, 2011
1,472
Preston
had problems standard then got an update from seat and had no priblems for months. mine hardly uses any oil either now as well
cupra-ads
471
Colchester, Essex
happens to both mapped and non mapped cars..however if your vehicle does have underlying problems...a map will make it worse.. wont cause problems necessarily but speed up existing problems
Beazy
273
cheers
I've had my 61 plate since August and put 5k on it with no issues, a lot of the issues seem to be confined to the older models...
In those 5k miles it has probably used around 2L of oil.
Mar 13, 2010
822
Its hit and miss to be fair, there is loads of 1.4tsi engines with no problems and some are awful, ive had not a bit of oil gone in just shy of 3k, but that could change, there has been some updates in terms of parts, if you do get one make sure it has warranty.
DeanzVrs
87
South Yorkshire
I was lookin at them round a 2010 but now reading what I've read I think tht I'd want a new one just to make sure it had plenty of warranty! Guess you can always buy a pup tho no matter what make or model, pot luck I guess
Aug 3, 2011
1,357
Mines done 11k from almost new with me, mapped for half that. Uses oil but well within limits. Mines an 11 plate, no updated spark plugs or anything. Just seat plugs.
Jay
wegi
Dakota Red Boc
Sep 20, 2012
180
Glasgow, Scotland
I just went out and washed my Boc then decided to check the oil after it... was totally dry!!! Only had a tiny wet dab of oil at the bottom! Luckily I always keep backup oil in my boot, but this is insane, I checked it 2 days ago and it was sitting at 3/4 of the way up the measuring part of the dipstick.
More than worried about this car now.
lucifer666
1,460
7
Cardiff
The 2012 engine is vastly different than I have from 09. Pistons/rings/injectors/spark plugs/magnetic superchager clutch/throttle actuator/pcv system/oil seperator/oil cooler.....there are more, cant think off the top of my head. I would by one now with confidence as the engine hasnt been dropped, it going ito more cars than ever.
Beazy
273
Mines did that :censored:
I came out of work on Friday and was greeted with this:
lucifer666
1,460
7
Cardiff
Mine did this last week also. Its related to the weather. We always seem to get more problems around this time of year regarding oil consumption + misfiring. Weird
Aaron_Cupra
67
Solihull, Birmingham
I'm getting the same problem at the moment. I also have had the dreaded 'emissions' light pop up. Changed the plugs to Ngk's, and not has the problem since. It is spoiling the whole experience of owning the car to be honest, as I don't want to boot it as I fear the worst from the 'fragile' engine. I dunno whether so sell up or not, cos I love the car :/ stuck...
lucifer666
1,460
7
Cardiff
make sure you have the new plugs by seat +software, should do the trick unless your consuming oil too then theres a different story alltogether. If your mapped, make sure you have the bkr7eix
Apr 13, 2011
1,971
hull
Always thought engines work better with colder air !
Bo engines don't work better cold try just run richer to compensate for the tempture will there warm the engine has less lubrication when cold the engine runs best at full running temp in cold foggy dam weather ;)
