1.2 spark plug removal?
adaytorememb3r
My car is stuck in limp mode and misfiring on cylinder two according to vag com. I've replaced two out of three of the coils already and don't think they're at fault.
I've ordered a set of spark plugs but when I went to take the old ones out my socket doesn't fit down the hole? It's too wide.
Is there a proper way to remove the plugs or am I needing a better fitting socket?
And also, am I going down the right path in trying to fix the misfire?
Cheers.
RUM4MO
8,068
1,102
South Scotland
Maybe you are using teh wrong size of spark plug socket, take one of your new plugs into Halfords and get them to match it to a spark plug socket. You should really use a torque wrench when fitting nw plugs as its too easy to over torque them.
louise ibiza re
110
dundonald ni
Same happened to me two of my coils failed and my spark plugs gave up as the gap was to big on them got them fixed and now the engine management light is stuck on do I need vag.com to fix this
samh1
had a very similar problem,turned out to be 2 of the injectors...worth checking those out,i changed spark plugs,ht leads and coil packs only to find the injectors were at fault
