01274 - Air Flow Flap Positioning Motor (V71)
01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes
* Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
* Positioning Air Flow Flap Positioning Motor (V71) blocked
* Positioning Air Flow Flap Positioning Motor (V71) faulty
Possible Solutions
* Check Air Flow Flap Positioning Motor (V71)
o See Measuring Value Blocks (MVB)
o Perform Output Test
o Perform Basic Setting
* Check/Repair Wiring and Connectors
Not sure if its the same on your car, but on a MK4/MK5 golf its behind the glove box.
Can you hear a clicking noise from the area when you turn the ignition on?
Have a look at this thread on how to replace etc
