Explain these codes please
Kris
ESTATE! I'm Getting Old!
Nov 21, 2003
808
North Essex
Hi,
following on from this thread...
http://www.seatcupra.net/forums/showthread.php?t=94411
Can someone please explain these codes
p0571 (16955) - brake switch `A` cir Malfunction
p1128 (17536) - Bank 1 mixture ADAP (multi) too lean
p1539 (17947) - Clutch switch input circuit `f36` implausable signal
p1602 (18010) - power supply (b+) terminal 30 low voltage
p0501 (16885) - vehicle speed sensor A: range perform
Thanks, :cry: :cry:
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
p0571 (16955) - brake switch `A` cir Malfunction your brake switch is broken
p1128 (17536) - Bank 1 mixture ADAP (multi) too lean your lambda sensor is dead
p1539 (17947) - Clutch switch input circuit `f36` implausable signal your clutch switch is broken
p1602 (18010) - power supply (b+) terminal 30 low voltage you've disconnected your battery
p0501 (16885) - vehicle speed sensor A: range perform your speed sensor is periodically up the swanny
I think you have some wiring issues around the pedal box.
D3DNA
391
Cov
Not all of them Kris, mainly the "p1128 (17536) - Bank 1 mixture ADAP (multi) too lean".
Kris
Nov 21, 2003
808
North Essex
ok, so I had the codes cleared and the only 2 that returned are...
I have realised that my car is in fact not going into Limp Mode, because I still get 5-6psi of boost.
Could either of these codes cause my car to feal sluggish and just not right!
