Finishing a smoothed airbox
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Having bought a TT airbox I set about trying to smooth it.
I've finished removing the mould lines / blades that run across the airbox. As you can see resut is somewhat less than smooth.
It is in fairness difficult to completely smooth it without spending an age sanding though. A few of us at Inters were discussing painting the inside with some sort of paint to completely smooth the rough edges.
Anybody got any ideas? Halfords do a vinyl paint which might do the trick?
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Sand paper will go so smooth but some of it is well below surface level.
Just looking to tidy it up a bit as well I suppose.
EddyH
263
Pontefract
I cut all the reinforcement ridges off with a knife then used a dremmel type tool to get it all smooth.
Looks like I'll be doing it again soon as I've just changed from the standard airbox to a TT one to accomodate a larger MAF.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
jimbo...
a pic of my smoothed airbox...
it took me 3 hours to smooth the lower half of the box! (i was hung over too! :lol: )
once i had got to ur stage i used a dremel and then i managed to get 3/4 of my eletric sander into the bottom of it (which saved me a good 1hour sanding!) and then i did the rest by hand! :blink:
was worth it tho! :D
ps. u have a screw in on of ur holes... dont loose it! ;)
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Looking at the pics, I managed to get mine a little smoother than that with the knife, then just left it :shrug:
CupraTgirl
Model Behaviour
Nov 8, 2002
2,468
England
I have been looking to do this to mine but am unsure of a few things:-
What sort of noise does it produce? Does it make it any louder?
Is it possible to get a new decent CAI to put on an Ibiza Cupra as i know there isnt much room with the standard box there between the airbox and the arch lining
What tools will i need?
Also mine is drilled so will that make any difference?
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
What's the difference between the LCR one and that on the TT apart from the extra hole? I was hoping to replace the LCR one directly with this TT one as I had been advised they were the same?
James said:
it took me 3 hours to smooth the lower half of the box! (i was hung over too! )
was worth it tho!
Looks like a good job there mate! I'll give it a go with my sanding equipment...
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i gope u dont mean my pics phil?! :lol: :blink:
my airbox is very smooth! :yes:
EddyH
263
Pontefract
I haven't got an LCR my standard MAF is smaller than that of a TT/LCR. I have a larger MAF as part of my big turbo setup and wanted to use an OEM airbox so I needed one from a TT.
LCR and TT should be a direct swap.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
u know wat mine sounds llike alex! :yes:
my DV is louder now as iv fixed my boost leaks, but stil VERY subtle, no where near as loud as an open cone filter! :(
but the sound of my BF makes up for it! :dance:
and u need to move ur battery over to get a decent cold air feed!
speak to phil (feel) for battery relocation brackets (not sure if he does them for ibiza tho!)
heres a pic of mine...
james :)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
CupraTgirl said:
Thanks J ;)
I think i need to get a different kit then to make mine 'tsshh' louder, dont i?
for me there are only two ways to go....
1) modified airbox
2) BMC CDA
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Cheers - They are pretty much the same, at least all the dimensions are the same. There's an extra outlet on the MAF side of the TT one which'll have to be blocked up.
You got me worried there... there is actually screws in both holes but I started to think that I'd already lost one...
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Ruddmeister said:
Or what about using filler, key the base of the airbox then a layer of filler, sand it back and voila super smooooooth
would rather sand it smooth, because id always have in the back of my mind... i wonder if is starting to crack and fall apart?! :shrug: :think:
