Has any one ever had an intake pipe split?
I was driving home from work quite happily when i realized it wasn't pulling quite right ,and a quick look at the boost gauge confirmed this it was only pulling 5 psi . After a look under the bonnet i discovered that the intake pipe from the air filter to the turbo was split from say 2 to 10 (if it was a clock face)at the turbo. Dont know if this is a common problem as mines only done 4000 miles, but as normal the dealer dont have one and its on back order so god only knows when i will get a new one.
Do you reckon its worth just replacing it with a samco one instead?
