i can re-drill the disks myself, that isnt a problem, i want to keep my car looking standard thougth so need to keep the oe wheels any one know if they fit?
You'll need to take an ickle bit of the calipers to correct the offset, but its an excellant VFM conversion. Doubt it'll clear a std 20vt rim - with Seat Sport APs not a chance in hell.
Yes & no, the pad carriers will need machining back by around 4mm on a TT/Leon/S3/Octy caliper to compensate for the offset difference, after that it'll bolt straight on.
You'll need to use TT/Leon/S3/Octy hoses's as they have a funny banjo type fitting IIRC, not so sure how m0rk got around that one...
used the hoses from the LC, just adjusted the mount on the inner wing to 'take' the different style - but it secured properly, so all is well in legal land.
