My Fault codes, zeee maf is dead i tink!!
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Finally got Vag-Com and as suspected i think my MAF is R.I.P, did a few runs and the maximum mac flow i achceived was 122gs, im on stock air filter. From searching i should be seeing 150ish right?
The codes:
17968 - maximun engine speed exceeded
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
18010 - power supply (B+) term 30 low voltage
16486 - Mass Air Flow Sensor : Signal too Low
The car is still boosting happily to 15 psi and im not getting limp mode.
Any ides chaps?
Russell
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
To borrow from Python,
It's not pining, it's passed on. This MAF is no more. It has ceased to be. It's expired and gone to meet its maker. This is a late MAF. It's a stiff. Bereft of life, it rests in peace. If you hadn't screwed it to your TIP, it would be pushing up the daisies. It's metabolic processes are now history! It's kicked the bucket, It's shuffled off it'smortal coil, rung down the curtain and joined the choir invisible!
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
Russ_20vt said:
The codes:
how did you get this one?
it wont clear btw, just in case you wonder :)
Russ_20vt
Kitesurfing nut
Feb 4, 2005
468
T,Wells. Kent.
Oh Saul, from reading up thats the rev limiter. As my rev limiter was removed when mapping, though i have no idea as i only rev my car to 6k anyway? im not to worried about that one.
