DV Relcation - anyone got fitting instructions/guide?
Pabs
5,936
Basingstoke
Hey all
I need a DV relocation fitting guide/installation instructions....
Anyone got them? Just wanna get an idea of how to do it and whats needed timewise etc..
Pabs
5,936
Basingstoke
theory is - you are using cold air rather than air from around the turbo which is hot.
Colder air = better ;) supposedly faster DV response and a bit better gains :)
Pabs
5,936
Basingstoke
while on dv relocation subject - how are the people that have done it getting on with it? OK?
Everyone use the std corregated hose from old/new location for the dv?
Nov 2, 2004
9,335
South Wales
I'm actually tempted to whip mine off and see what its like without it. Do some before and after logging.
Seems to increase lag i found tho. Maybe its my imagination. I also found a 'softer' springs works better, i've tried up to a blue one and found the green was the best/.
Pabs
5,936
Basingstoke
hmmm really? I am gonna give it a go and see what happens - I am trying to fix my "chatter problem and by relocating the DV so its easier to get to, so i can swap springs is also a bonus :D
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
pabs - if you have chatter, you will want a slightly stiffer spring - NOT the blue one though.
I think it's yellow that the DV doesn't come with - that's what you want to have. - fixed jonah's a treat (that ran DV relocation & similar spec)
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
i need a new yellow spring too, i think mines fooked.
having a standard map, then non standard then standard now remapped again cant have been good for it, think ill contact forge tomorrow.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
won't have made any difference brendy.... not like the car runs max boost all the time.
email peter @ forge & a spring is normally a day away.
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
haha your right, i do have to stop for traffic!!
i think 30 k in a year might have reduced its effectiveness i think ill give it a go.
(ps any sign of that ecu mate?)
Pabs
5,936
Basingstoke
thats EXACTLY THE OPPOSITE to what bill said to me. I have already upgraded to a stiffer spring - bill says the chatter is the DV not working properly, and so u need a WEAKER spring.....
I need to go back to the other spring (the original)
Pabs
5,936
Basingstoke
from what pete has said the dv relocation helped make DV react faster... I have no idea what its gonna do really.
I get confused cos I dont know the answer to fix it, but get told different things. All I can do is keep trying solutions until one of them works.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Deffo reacts faster on mine (LCR, DV in stock location but take off moved to cold side) and I'm tempted to reduce the spring stiffness from what I ran in the stock location.
On mine, if I floored it, lifted off then floored it, it would hesitate - that's gone with DV relocation and it definitely reacts faster on gear changes with the relocation - picks up better afterwards.
Tallpaul
821
i took my DV relocation kit off. It made absolutely no difference to anything.
Maybe bigger benefits with a remap (with higher temps).
Did keep the DV itself nice and cool though - that in itself must be beneficial, no expanding/contracting :shrug:
Glenn
513
If by "chatter" you mean what I think you do, I've had the same issue on my Ibiza running the green spring. It was reduced by a refitting the DV the right way around - boost goes in the bottom & vents to the side (not sure how mine got reversed?) and all but eliminated by replacing the green spring with a blue one, courtesy of Martyn for letting me try it and Forge's top-class customer service (email to Richard on Friday, spring arrives FOC on Saturday morning). I suspect that with the rapid rise in boost of Revo, that the manifold pressure applied to the top of the DV is lagging the boost pressure at the bottom and causing the DV piston to lift slightly as it overcomes the preload of the spring - green spring is softer than stock Bosch DV. I'm going to try bypassing the N249 and trying stock DV, green & blue springs at some point to see if the issue is DV-preload related or N249 related.
Pabs
5,936
Basingstoke
my DV is the right way around.... it doesnt happen very regularly at all. TBH only when in low revs with foot on the floor, and in a high gear. Ie 20mph, 1.5k revs, flooring it and when i release the gas it does it.
I have spoken to loads of people - m0rk, Bill, others on the forum, revo, forge, and nobody seems to be able to solve the problem.
Its a weird issue. Hope to figure it out eventually :)
Pabs
5,936
Basingstoke
People, this is a picture of the previous owners relocated DV.
Please confirm, this DV is in REVERSE.... correct?
The side pipe should be connected to the original location, and the base pipe should be connected to the intercooler hose?
Just checking before I fit mine in about 12hrs time ;)
ta
