Urgent starting problems
Ian_Dublin
Guys
on starting my leon tonight the car when i turned the key the engine was starting to turn over but car would not start (sorry not the best discription). Engine started when i touched the accelorator and turned key, drove a short distance home, not half a mile, while driving the engine was racing and rev counter was sticking at roughly 2500 revs and kept racing up.
any ideas what this may be, engine isnt idleing below 2ooo revs
cheers
Ian
Distant Sun
Contains mild peril
Sep 9, 2005
79
Belfast
I'm assuming yours is a petrol model like mine. I've had the starting problems several times, and and also the problem of the revs sitting really high. Dealer cleaned and reset the throttle bodies, though the resetting didn't always work first time (car sits at high revs for several hours/days: it's meant to re-adjust itself gradually, though dealer couldn't say how long it would take), and the car had to go back in.
Also had the throttle bodies replaced under warranty when the problem first occured.
The last time it happened (revs would intermittently stick at about 5000rpm) I tried the resetting of the throttle bodies trick (turn ignition on but don't start the car, let it sit for 2 minutes?, switch off and then start up and bodies should have reset) but it never really worked for me. There's info about this on here if you do a search, but also lots on the MkIV forum. If the ignition trick doesn't work I'd take it to the dealers. Think at least once the dealer also replaced the engine temp sensor to cure the starting problem.
Hope this helps
nej
Could easily be a temp sensor - I had a similar thing in a passat not too long ago.
Get a VAG-COM on it.
