For those changing to LCR front suspension
Ronin225
4,652
22
Worcester
Got some comparison pics for those who currently run a normal cupra setup but are wanting to change to the LCR/S3 style setup.
To do the conversion you will need:
1. LCR/S3 wishbones (larger cast ones requiring different size bushes to cupra)
2. LCR/S3 or uprated in these style front anti roll bar
3. Droplinks to suit
4. Struts with brackets to attach to droplinks instead of to wishbone like cupra (many aftermarket coilovers have these even if for the cupra)
5.Hubs - There are two different types dependant on the age of the car
Older cars have hubs that have nuts like below
The newer style have an allen bolt fitting like this
Make sure that the type of hubs you have match the the style of the LCR/S3 hubs or you will need to change the driveshafts to suit these.
Since i had the chance i thought i'd get a few pics for reference for those who intend doing it
csd_19
2,280
28
Angus / Edinburgh
You'll also want to get the entire hub carrier, the LCR/S3 ones are longer and hence the wishbone angle stays more "correct" once the car is lowered, keeping it away from the bump steer the LC setup develops once lowered.
Ronin225
4,652
22
Worcester
Not really sure as my LCR came with it all standard
With so many LCR's/S3's being broken you should be able to get the part cheapish now
csd_19
2,280
28
Angus / Edinburgh
You should also either get LCR trackrods and rod ends, or swap your existing ones from side to side.
Non-LCR track rod ends have the nut underneath the hub carrier, LCR has the nut on top - the non-LCR setup exacerbates bump steer when you lower the car.
If you do swap your existing ones, make sure you set them up with the nut now on the top :)
csd_19
2,280
28
Angus / Edinburgh
Depends what you'd class as a decent handling gain - when you lower an LC the angle the wishbones and steering arms point at is ridiculous (which perversely raises the roll centre and makes handling worse), the LCR setup keeps things a lot more in control.
bangerstox10
83
CANTERBURY
Sorry to bring up an old thread but with regard to the hubs and driveshaft, how do I know the difference on the hubs if I don't have the shafts
bangerstox10
83
CANTERBURY
Right I think ive got the later style hubs for my conversion, is it possible to change the flange to the early type so I can still use my original shafts as they are fairly new?
tia Paul
Rich79
When I had this conversion done on my octavia vrs the garage just pressed my existing hub flange in the new hub along with new wheel bearings
