Air metal heat shield
seatcupramad23
kc4even23
Sep 7, 2009
3,239
birmingham
i have one , its more for blinging up engine bay to be honest cause had it fitted to my lc couldn't really feel much difference in terms of performance but i bougght another one just to bling up the bay a bit
Trublu07
1,334
Essex
I was looking at this also. It does not seem to be the same quality as the Jabba one. It might look better in the metal do to speak but looks flimsy.
Trublu07
1,334
Essex
I have fitted mine tonight. It looks well made and strong. I have bolted it to the screws by the battery tray and suspension strut. It does not fit into both screws easily and you have to apply tension to get the strut one to fit. The maf screws do not sit flush with the sheild either but I am unsure if this is because of my tip (as they all vary in dimensions). My concerns were it not fitting flush and the fact that it is a small bolt taking the tension on the screw hole by the suspension strut.
Pics:
And the ones from the eBay ad for comparison:
Has anyone else bought one that can share their experiences?
vwdom
136
rothwell,northants
mines under tension too but not enough to worry about. i know what you mean you have to put one bolt in then pull it slightly to get the other in i wouldn't worry about it.
oh and i'd screw the maf to the heat shield, i just used the standard maf screws
