Interior lights not working?
pods_f1
:confused:Hi there, have a problem with my interier lights not working, from the back passenger roof light and the front main driver and passenger roof lights. No bulbs have blown and all the fuses are fine? (7.5-10a) Could it be a relay:confused: Nights are drawing in now so they would be usefull to use! (seat leon mk2 06 plate.... cheers.
Jan 31, 2011
511
ipswich/banbury
when i bought mine also a 06 plate they didnt work. it ended up being a contol unit (the same one that controls the central locking etc and its behind the dashboard i was told). luckily was covered from the garage because it cost 300-400 quid from the stealers to sort.(if you do it yourself it needs programming to the car)
Tim'o'thy
i Had the same problem 57 plate fr.
went to the dealer and they replaced whole unit, they said its down to them and was all sorted in a matter of minutes!
Kadiea
I have the same problem at the moment. I took out all the fuse's and they were all fine. MY interior lights and my rear window DE-fogger doesn't work.
This all happened because i put LED bulbs in my interior lights and it just stopped working after that.
pods_f1
Interior lights.
:confused:Hi there mate, yer i forgot to mention mine became faulty when i tried to put led bulbs fitted with resistors in my number plate lights? so none the wiser as to what has failed and what i need to replace? possibly it could be an onboard control unit as like yours any more idears people??:help:
