ccv removal
samm
Oil be back!!
Nov 5, 2003
498
Horsham
sammullahy.50megs.com
sssstew said:
IIRC = if i remember correctly.
but from what ive seen of the PDs its simply clamped in place as paulo says, so a quick un clamp and then do the business with a bypass system.
Please excuse my ignorance guys but what exactly does doing this achieve?? :confused:
prc
Sooty Meister
A couple of things:
most important is that you won't get oil into your intake system + intercooler. If you remove your IC after 50K and look at the gunk that's deposited there you see why. :scary:
you'll also get more cooler air from the exterior (via airbox) + it'll be measured by the MAF.
samm
Oil be back!!
Nov 5, 2003
498
Horsham
prc said:
A couple of things:
So if this is the case, why do they not design it to stop this or bypass it from new? Surely the intelligent people @ VAG know about this and would deem it a problem? :confused: :confused:
muddyboots
Still hanging around
Oct 16, 2002
5,739
prc said:
A couple of things:
How does it make you get more cooler air, I thought the CCV gunk gets added downstream of the MAF so it wouldn't know any different ?
sssstew
Editing your spelling
well rather than the combustion cycle sucking in air from the CCV pipe which is a bit oily and not as clean and crisp as fresh air, by passing the ccv allows all the intake air to come from the outside thus more rich in oxygen and cooler for a better combustion.
Erm not sure about the MAF, sorry paulo :( but its pre CCV and EGR as muddyboots says.
prc
Sooty Meister
samm said:
OK, so when it comes down to it, is it really worth doing? Also, are there any pics of how to do it?
The cold air bit is exactly as mentioned by Stew. I'm not saying that it's a bit performance upgrade, but it will save you having to clean out you intercooler and intake tubing every so often.
As for pics...there are some around. I have been promising an guide, but just haven't had the time to get around to it.
sssstew
Theres some links in the TDI FAQ about CCV bypass stuff that paulo has done, also theres loads on tdiclub.com forums for example :-
http://www.angelfire.com/wi3/rks/ccv.html
http://forums.tdiclub.com/showflat.php?Cat=&Board=UBB3&Number=12846&page=&view=&sb=5&o=&fpart=3&vc=1
http://forums.tdiclub.com/showflat....d=allposts&Main=475276&Search=true#Post494787
and yes its worth doing if u can be bothered, if done along with turning the EGR off you can elimiate the oily deposits in your intake and intercooler, when mixed they do this :-
http://forums.tdiclub.com/showflat.php?Cat=&Number=678875&page=2&view=collapsed&sb=5&o=7&fpart=1
muddyboots
Oct 16, 2002
5,739
OK, so it isn't a performance upgrade as such, but it might reduce any degradation that would otherwise happen over time due to everything clogging up with oily shite...
cheshire cat
1,813
cheshire
It's the actual fitting in the cam cover top not just the pipe to the inlet tract. Oily shite about sums it up, even after just a few thousand miles. I hadn't considered the -volume- of HOT oily gas going back in there but it must be considerable when turning over at a few thou rpm. If this is the only design fault we are doing well.
cheshire cat
1,813
cheshire
ccv
thanks for the links ssstew, I had thoughts of making something like the "OLD NAVY" type but obviously need to remove the VW one first to see how it's fixed, cheers Nic :idea:
Tom_vRS
Sorry to dig an old thread up - BUT...
Are there any commercially available CCV bypass kits, or only home made DIY jobs? :confused:
