Got a 3y 8m old 140pd and today after 2 minutes of motorway it went into limp mode and I was stuck at 65mph.
I pulled up at the next junction and drove round it a couple of times before parking up and turning off the engine. Restarted and it was the same. Turned off again and then opened bonnet and restarted, gave it a good rev and then tried again and all was well. I did my 50 mile trip at a good rate of knots and then later in the day was 45 miles into coming home and it happened again.
Tried the car again a few hours after and all is well. I can't find much on here (seems to be mainly dpf issues) but seen some stuff on other VAG forums saying veins may be blocked.
here's one insert.....
yep, i'd second the sticking turbo, exactly the same as i had on mine from your description.
wd40 on the actuator and linkage and a good shove backwards and forwards a few times, and its been fine for the last 12000 miles.
Can anyone give me any advice??
