Charcoal canister removal , help
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
rip out all the piping dan and leave the Canister pluged in to the actual circle bit on top which pulls out the box....
then Blank off the nipple on top of the Throttle bodie im doing mine today...you will get a EML light every so often but it wont effect the car at all..
Im thread digging at the moment for a Resistor for it....and same for the n249....
CJRamze
Proud Seat Owner
Jun 29, 2008
2,015
Caldicot, South Wales
What is its function?
I see alot of people removing alot of things from the engine bay and It makes me wonder because if they did nothing positive they wouldn't really spend thousands on RnD
CJRamze
Proud Seat Owner
Jun 29, 2008
2,015
I see, So will the removal of the canister increase emissions?
Not really a worry for me I'm running decatted, just incase people search in future! (Like noobs EVER search ANYTHING)
May it cause you to fail your Emission test in the UK?
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
I have also read about running some vac line from one of the pipes down the wing also not to block some thing or the fuel will implode or some thing lol so need to make sure I do it right
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
Dan i was looking into this a while back. On the early vag cars they just had a vacuum hose with a inline n80 valve with no carbon canister as standard. Could get one of these n80 and run it the same way. Just a thought.
The gaffer09
Spooky, that was my next question. Is it on the left hand side of the engine bay? Black box type thing, heard it clicking yesterday a thought wtf lol
BBoy82
Dan the compressor man...
Oct 25, 2008
293
East Northants
What does it actuallydo?
Where is it connected to?
If its an activated carbon filter for oil vapour removal, then it should get replaced at some point, as the carbon media will eventually become saturated surely?
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Dan, i removed mine a while back the light comes on nearly every day, really did my head in so i put it back, but only plugged in and with the vac hose to the mani, the fault i got was incorrect flow so nothing the resistor will stop its the ecu picking up on somrthing.
Murdered LCR
Wide mouthed mofo
Sep 9, 2006
6,646
8
Murder Inc.
Phil my light is on constantly because of my de cat so I'm used to it , at some stage I plan to get a liquid gauge to clear codes etc as and when , it's really easy to remove tho , pics will be in my rr soon along with loads more :)
