Face lift Cupra with Needle sweep.
HotHatchSteve
850
I would say it depends on what Control Module you have for the Instruments. If you have access to VAG COM to compare, mine is Address 17: Instruments 1P0 920 952.
KWEV
97
Just checked my FR FL 170 Cr MY10 with VCDS and the module in mine is Address 17: Instruments 1P0 920 954. The 'staging' is there to activate under the Adaptations tab, but just like to check before i hit the button. once you have chosen 'activate' and hit 'do it' an info box pops up stating something like workshop authorise code required......do you want to use vagcom 12345/123/12345 code instead either YES or NO are the options.Is it ok to hit yes at this point? :shrug:
If it is then hopefully it will be functional for us diesel guys:p
Thanks to 'hothatch steve' for the thread:)
KWEV
97
He he ............works a treat on the FL FR diesels too, just follow what steve has said.....job done:):funk:
