Folks,
Has anyone successfully done this:
http://wiki.ross-tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration
Im not having problems at present (driving style seems to suit DPF, touch wood of course) but just interested should the inevitable happen. I do feel the regen kick in every few hundred miles and am conscious of keeping revs as near to 2000rpm on a daily basis.
I would also be interested in seeing if its worth doing the above every month or so to keep soot levels down, if that’s appropriate.
Just for interest, does anyone know if the ECU forces the regen (once the 25% or whatever levels have been reached) until it drops to 0% or does the regen stop after it drops just below the 25% threshold again (give or take a bit for instrument hysteresis etc)…?
If anyone has had success, I would be interested on how easy this was and if it was done with an example of the finest Chinese import VAG Com cable or a full whack RossTech version.
Many thanks,
D
Many thanks,
D
