Boost control
Pyro
Rite I got my spps3 switch and have been playing with boost but after turning it up and nothing happening I'm starting to wonder what's goin on :( surely if I turn the boost up on the sps3 then it should peak higher????? It peaks at 18-19 and wjen I turn it up it still peaks at the same :( it's set to 6 on the switch and feels no different from there on??? 7,8, and 9 just feel slugish?? :(
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
More boost = more heat, so it's just getting hot.
Bigger, decent intercooler and you can start tweaking
Pyro
But shouldn't it still show on my gadge that its requesting more an peek higher?? Even if drops to the dame as before?
Pyro
Ahh I see so I'm guessing to test this I can change the boost while the cars cold and see if it does peak higher?? If not then I do I have a problem??
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
No, you're not getting it.
Boost = heat
Summer = heat
too much heat = ECU pulls back boost = less boost
Pyro
No I no what you mean mate but just wondered if it would be different for the first five mins driving before it all warms up but I have my answer thank you
