Leon mk1 front lights out!!
47poles
Hello All, can anyone tell me if there is a seperate fuse for the normal driving lights on the mk1 leon cupra tdi? Side lights, fogs and full beam are all working.
Any helps would be much appreciated.
47poles
Checked the bulbs and about to check the fuse, but wondered which one it was and if there was a seperate fuse for those lights?:)
mark1231
146
Fuse (Amps) Circuit
F1 (10A) Heated door mirrors, heated windscreen washer jets
F1 (10A) Heated windscreen washer jets, glove box lamp (11/99->)
F2 (10A) Indicators
F3 (5A) Glove box lamp
F3 (5A) Instrument panel (11/99->)
F4 (5A) Licence plate lamps
F5 (7,5A) Heated front seats, air conditioning (AC), cruise control
F6 (5A) Central locking
F6 (5A) Electric door mirrors, electric windows, central locking (11/99->)
F7 (10A) Reversing lamps
F8 (5A) Telephone
F9 (5A) Anti-lock brake system (ABS)
F9 (5A) Anti-lock brake system (ABS), electronic stability programme (ESP), Haldex coupling (11/99->)
F10 (5A/10A/15A) Engine control module (ECM) - petrol
F11 (5A) Instrument panel, transmission park position interlock solenoid
F11 (5A) Instrument panel (11/99->)
F12 (7,5A) Telephone, data link connector (DLC)
F13 (10A) Stop lamps
F14 (5A/10A) Interior lamps, central locking, electric windows
F15 (5A) Instrument panel, automatic transmission (AT)
F16 (10A) Engine coolant blower motor control module
F17 -
F18 (10A) RH headlamp - high beam
F19 (10A) LH headlamp - high beam
F20 (10A/15A) RH headlamp - low beam, headlamp adjustment
F21 (10A/15A) LH headlamp - low beam
F22 (5A) RH side lamp
F23 (5A) LH side lamp
F24 (20A) Windscreen washers
F25 (25A) AC/heater blower motor, air conditioning (AC)
F26 (20A/25A) Heated rear window, heated door mirrors
F27 (10A/15A) Rear screen wash/wipe system
F28 (15A) Fuel pump
47poles
Thanks for all of your adivce!
I am going to go out and have a look now, hope it's not the switch! Does anyone know where to get a second hand one if it turns out to be that? It seems likely as both lights seemed to fail at the same time!
Thanks Again.
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Best trying the breakers on ebay, can't recall the new price.
Try the dealer seremotors on here if you do go down the dealer route for new ;)
47poles
Well the bulbs all look fine and the fuses are both ok. Looks like I need a switch. I have looked on e-bay but don't really know what i'm looking for. Can anyone help? Is it the main switch that which controls all the lights or a smaller part???
47poles
Does anyone know where I can get a main light control switch on the net ASAP?
47poles
Thanks Andy.
How would i test the switch, i wouldn't know where to start!!
Cheers:)
