Lambda and Catalyst: codes 16804 and 16514
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
Hi guys..
I'm getting the following codes regularly after clearing them..
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
I get an occasional pop/misfire between gears when booting it. No other codes logged.
I've done a fair bit of searching and it seems some folks found a lambda replacement solved it, others did plugs. Can anybody suggest a cheap source of lambda probes? ...and is B1 S1 the one before the cat?
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
Well, I've found some info now..
Manufacturer Part..........................................Bosch Part
06A906260N (Front sensor)...........................0258006213
6K0906262B (Rear Sensor)...........................0258006266
Off to buy front sensor from eBay - can somebody add this to the parts FAQ, it might help us save cash.
B1 S1 is indeed before the CAT.
RichN
Collecting Rings
Jan 29, 2005
533
Oxford
www.Oxford7s.net
Well, I started and finished my own question here so I thought I'd post up that a change in Lambda sensor, pre-cat seems to have resolved this. I found the part for £65 on eBay, the original Bosch sensor as above, which is much cheaper than the dealer.
Easy to change, too.
Hopefully this will help someone in the future.
Indy
MK1 LC Red Devil :)
Sep 8, 2005
200
Uxbridge
Hi, Got the same error today when getting the MOT done...
You have answered my question regarding where the sensor is B1 S1 before cat and will have a go at this over the weekend. Thanks.
