split TIP
Nev_LCR
Gone... but not forgoten
May 16, 2007
1,271
Ipswich, Suffolk
just taken off my old TIP as i have a new one coming,
the car has only done 16k miles and it looked like this.......:scary:
would it of caused any issues, there was no codes and felt like it was running fine.
Ronin225
4,652
22
Worcester
my TIP split in exactly the same place but about 90% of the way round which used to send it into limp mode everytime i drove it. my car was 2 and half years old and done about 18k at then. cheap crap pipes. in the process of uprating all mine too, just got TIP and uppers left
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
I changed nibbles's pipe for him after he had a service at a seat dealer with 20k on the clock.his was split in the same place.mine had done 30 k and was fine its in the shed now.
Jun 26, 2008
1,299
Just round the corner.
The reason for them splitting, is due to oil breaking down the rubber.
Are the Cupra and Cupra R TIP's the same? I'll be looking into replacing mine for a Forge Silicone item.
Dec 6, 2008
612
Shropshire
Forge list a few which are differed by engine code, even if you source it elsewhere look it up there first then you know what part to source.
And yes I'd have to agree about the oil perishing the rubber. Another problem with rubber pipes is mice although that wouldnt be the case here
Nev_LCR
May 16, 2007
1,271
Ipswich, Suffolk
no they are not the same,
i understand about oil perishing the hose but not after that length of time, i think its dye to the clip on there,
i think my pipe just shows its worth checking
Dec 6, 2008
612
Shropshire
Has it been on from new? you didnt say what length of time but am guessing its 2 years. Thats quite a while, plus other things can affect the rubber, WD40 for instance also perishes rubber, it may have been off before you brought the car.
