Leon alarm Issue
Deepsix
Hi all
I have a strange problem with my 04 leon 1.6sx, a couple of weeks ago the alarm started going off and the boot open light was on very dim, although when you put the side/headlights on it went off.
After reading this forum i disconnected the boot switch and the dim boot light went off, for over a week the alarm was fine, job done (or so i thought!!!!)
I was woken up at 5am Sunday morning by the Leons alarm, again the boot open light was on very dim (still disconected). i removed the bonnet switch and it was still the same.
When the boot light is on dim the alarm sounds as soon as it is set....
When the alarm module is disconnected (right hand side under dash) the boot open light glows dim!!!
i have checked for fault codes with VAGCOM but nothing, is there a measuring block i need to look for......?
Is there any nown faults with alarm modules...??
Can i just turn the damm thing off as a temp measure...?
Thanks in advance
Steve
Deepsix
when you say the open boot light light.. are you referring to the light in the boot, or on the dash?
if on the dash id be looking at the boot switch mechanism.
Hi thanks for the quick reply
Its the light on the dash and the boot switch is not connected, thats the strange thing
Cammage
Turbo Time...
Oct 16, 2007
59
Leeds
had this problem myself 2 weeks ago. In my case an elbow off the rear wash wipe had come loose and was squirting water onto the electrical connections located behind the boot light. This whole panel (the bit that holds the light in) comes off with abit of strength and a screwdriver. I dont know if this is where your problem lies but i reckon its a place to start as there is this elbow which is guaranteed to come off located directly next to some connections........stoooopid.....:shrug:
kevinmac87
Same problem on my car the boot open light is on the dash but sumtym wen i turn the rear wiper on or squirt washer on the boot it goes off and my alarm has startd playing up the last cuple days aswell. Is this an easy enough job 2 do?
Feb 22, 2009
3,618
South Wales
mine started doing this tonight - not happy - pics of what I need to remove to solve this today
was very cold and took around three hours although I did not rush did not want to break anything
firstly here the dash with the dim warning light
so followed guides on here and removed the boot trim to find no fault - did not break any of the 8 clips :)
3,618
South Wales
so onto the side panel
1 started with the screws below the lamp unit
2 then the one behind the seat and pull shelf panel away from the side of the car to unclip
3 next to go was the trim behind the rear light cluster one screw and a good pull
4 this gave access to the side carpet panel and exposed the foam block which needed to go
5 now you can see where the screenwash collected
3,618
South Wales
the small flood of screenwash here confirmed to me I had the leaking joint
6 carpet removed and I find the leaking joint
you can also see the plugs above which are soaked with screenwash
condition of plugs
cleaned and soaked with WD40 (allthough other brands are available)
put it all back together and works fine no alarm so far :)
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Had the same problem which is how I found SCN.
sensor on boot was playing up, locked fine then slowly light came on dim then increased in brightness.
this fooled the alarm that boot had been opened and set it off. Pain.
Lots of WD40 then played with mechanism for a while, opened and closed boot loads,
sorted. Although I think I have the same problem with rear wash squirter leaking too so thats another one to fix when it's dry. Nice pics and guide Mark top job.
rackha
57
west midlands
damaged wires
had the same problem with mine but one of the plugs had corroded so badly that wires and connectors are damaged and will need replacing. does anyone know what this harness feeds as i've had to temporary disconect untill repair and every thing seems to be working fine so far including boot lock.
6th.replicant
698
9
London
Also had same problem with a 'phantom' boot-open light on dash triggering the alarm.
However, in my case, the cause is a snapped screen-wash tube - where it joins the rear wiper motor - leaking onto the boot latch, which is activating the aforementioned warning light that, in turn, triggers the alarm.
Can the screen-wash pipe be re-attached? Of course not. Hence, a new wiper motor appears to be the only 'cure'. Considering that the current wiper motor works fine, this seems to be a senseless, wasteful & relatively expensive (£80-ish + VAT) solution.
Alas, yet another example of VAG's currently poor underskin engineering & design. [:@]
BTW, as a temporary fix: remove fuse-14(?), which de-activates the alarm but the immobiliser will still function, as will the central-locking, albeit via key & the driver-side door lock. And it'll also disable the electric windows & mirrors, the interior & door lights, & the headlights' full-beam dash light.
Feb 22, 2009
3,618
South Wales
could have done with this info christmas time
MMA FR150
MMA Team Gladiator
Jul 4, 2009
50
stoke
Early morning nearly 4 had no sleep alarm going off constant woke up all neighbours does wd40 and cleaning connections work before I am not a happy chappy my lcr is begining to P me off :( by way the faint boot open light is on!
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Good clean out with WD 40 work the latch loads to and open and close several times, then actually open and close boot hard several times. fixed mine but second time round. The first time only fixed it till I hit a bump then light came back on and I knew I was in the right direction but needed another go, which I did and no probs ever since. If that makes sense.
I do have a prob with the rear window squirter as stated earlier on in thread but, that does not effect my boot and alarm, so try WD40 first. Does your rear screen wash work ok?
MMA FR150
MMA Team Gladiator
Jul 4, 2009
50
stoke
Go it in seat today had diagnostic done nothing light was out drove away got tyre fitted light back on went to volkswagon booked it in driving home light out think my car is playing me up now have got a small leak in boot so needs sorting
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Small leak sounds like the screen wash tubing or joints have gone, sort as shown earlier in thread mate.
MMA FR150
MMA Team Gladiator
Jul 4, 2009
50
stoke
Took it volkswagon 45 quid initial investigatio found and cured problem in allotted time awesome the connections had corroded and washer modification top up oil as well road test 56 quid bargain. No more sleepless nights for me haha
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Well jet washed mine this week and ended up with a flooded drivers foot well WTF!!
Thought pollen filter was other side so what's that all about???
