Leon Lubricants - June'08
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Leon 1.4 16V 1999-2005. (75HP) (AHW)
Engine: 504.00 - 5W-30.
Gearbox: VW G50 - 75W-90.
Brake/Clutch: DOT 4.
Steering: VW G 002 000.
Cooling: VW G12 TL 774-D.
Leon 1.4 16V 2006>. (75HP)
Gearbox: VW 052 726 - SAE 75W.
Cooling: VW G12 TL 774-F.
Leon 1.8VT Cupra 1998-2005. (180HP) (AUQ, ARY, AJQ, APP) KO3
Engine: 504.00.
Gearbox: VW G51 - 75W-90.
Leon 1.8VT Cupra R 2000-2005. (225HP) (AMK, BAM) KO4
Engine: 504.00.
Gearbox: VW G51 - 75W.
Leon 1.9TDI 1999-2005. (90HP) (AGR, ALH)
Engine: 507.00.
Leon 1.9TDI 2000-2005. (110HP) (AHF, ASV)
Engine: 507.00.
Leon 1.9TDI 2004-2005. (130HP) (ASZ)
Engine: 505.01.
Gearbox: GL-4 - 75W.
Leon 1.9TDI 2001-2005. (150HP) (ARL)
Engine: 505.01.
Leon 1.9TDI AWD 2001-2004. (150HP) (ARL)
Engine: 505.01.
Rear Differential: VW G50 75W-90.
Haldex Clutch: VW G 052 175.
Leon 1.9TDI 2006-2006. (100HP) (AXR)
Engine: 505.01.
Gearbox: Vw G50 75W-90.
Leon 1.9TDI 2006>. /w Diesel Particulate Filter (105HP) (BLS)
Engine: 507.00.
Gearbox: VW G 052 726 75W.
Leon 2.0TFSI Cupra 2006>. (240HP) (BWA)
Engine: 504.00.
Gearbox: Vw G 052 171 70W-75.
I shall keep adding other variants of the Leon family. Watch this space. Then I shall do the Ibizas.
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
you got 507.00 on the 110 TDI is this corrct? as I thought it was a new oil??
Seat, León, León 1.9 TDi (81 kW), 2000-2005
Manufacturer: Seat SA, Barcelona, Spain
Drive type: f.w.d.
Cilinder capacity: 1896 cc
Power output: 110 HP / 81 kW at 4150 RPM
Engine AHF, ASV
Capacity 4.5 liter
Filter capacity: 0.7 liter
Use: Normal
OEM recommendation
year-round VW 505.00 SAE 5W-50
year-round VW 505.00 SAE 10W-50
year-round VW 505.00 SAE 10W-60
Above -15 VW 505.00 SAE 15W-40
Above -15 VW 505.00 SAE 15W-50
Above -15 VW 505.00 SAE 20W-40
Above -15 VW 505.00 SAE 20W-50
Below 15 VW 505.00 SAE 5W-30
Below 15 VW 505.00 SAE 5W-40
From -15 to 15 VW 505.00 SAE 10W-30
From -15 to 15 VW 505.00 SAE 10W-40
year-round VW 505.01 SAE 5W-40
year-round VW 505.01 SAE 5W-30
year-round VW 507.00 SAE 5W-30
You may aswel put the best stuff in :)
507.00 5W-30 which covers 505.01 & 505.00.
Hope this helps.
vwbassett
Joined the Dark Side
Aug 13, 2007
963
53
Surrey
From the dealers i picked up some transmission fluid for a Cupra R 225 2004 which isnt G51 but G 052 171 A2 is this still compatible? although its a bit late as its already in there.
Adam
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Adam
VW G 052 171 - Gearbox oil SAE 70W/75.
VW G 51 - Special synthetic gear oil SAE 75W/90.
70W/75 seems thin for a 225BHP gearbox, if it starts feeling rough after its warmed up then try something like this > http://www.opieoils.co.uk/p-981-fuc...w-80-synthetic-manual-transmission-fluid.aspx
vwbassett
Aug 13, 2007
963
53
Surrey
Oh dear, if its what a dealer has supplied i feel a bit annoyed as its a waste of my money for expensive fluid and my time changing it. Will wear be increased? think id rather change it back sooner rather than later
ChrisGTL
'Awesome' LCR225
Nov 17, 2007
2,459
Huddersfield
Hard to say if wear will be increased. Without knowing what oil it is, and not knowing what extreme pressure package is in there its hard to say.
Ask them why they put a 70w/75 in. See what they say and report back here.
Does your gearbox feel nice with this 70w/75 in?
SCOTTIECTR
can anyone tell me what oil to put in my 05 fr TDi please, in terms of 5w or what please.
thanks in advance
SCOTTIECTR
Thanks Chris, I've got some Total 5w/40 fully synth, that should be OK shouldn't it?
Nautilus
547
Bucharest, Romania
Warning: power steering fluid as filled up by factory is not the green stuff (G 004 000) currently sold by VAG dealers, it's standard yellow fluid. To fill up with green fluid the entire system has to be drained and flushed. I had to top up (it was at minimum level) and used normal yellow fluid
~Nautilus
