Pollen filter
Ibiza 130 tdi
Black Magic
Jan 15, 2007
6,275
Somerset
I think my pollen filter must be blocked. After using my air con my windows steam up badly. It's fine if i've used ECON for a while but if I use the air con for a while and switch back to ECON - the windows steam up.
So there isn't a leak - it's something to do with the air con itself.
I've searched and found that the pollen filter is under the glove box somewhere. But the description wasn't very clear so just wondered if anyone could give a more detailed - easy to understand description of how to get to the pollen filter and where exactly it is under the glove box!
Thanks in advance guys!
Ash
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
I'm pretty sure its to the right, under the glove box, next to the centre console. It is mounted vertically and you kind of slide it out downwards after sliding a couple clips which hold it in place.
Ol' Timer
873
Norfolk
You have to remove 4 screws from a cover under the glove box first and then do as kriso says. Lay something on the carpet to collect any debris which falls out.
