I've had a search but can't find a previous thread on this (hopefully I'm not going to get flamed for missing something obvious now
I got a nearly new leon FR (petrol) about 2 months ago. It was 12 months old but had only done 2900 miles. For the first 2 or 3 weeks, about 1500 miles(I drive a long way for my job), the car was fine, so I was having a great time.
Since then though, I keep getting a warning light on the dashboard about the exhaust quality- something fairly generic. When I take it to the garage (its been 5 times now for the same problem), each time they
around with it for a bit and then pronounce it fixed. I then drive it between 20 and 200 miles and the warning light comes back on again. There doesn't seem to be any common theme to when it comes on either.
I have now been told that it won't run on 95 RON fuel, I have to buy superunleaded only. This seems like a load of rubbish- the manual and label inside the filler cap both indicate that although 98 is preferable, 95 should be fine, albeit with "slightly reduced performance". Also, why has it taken 5 visits for them to "remember" this?
When I'm communting on busy roads and motorways I don't want to have to fork out significantly more on 98 fuel when I'm not going to notice the difference (if there is any- cue more flaming
Has anyone else been told this, and does it sound like a fob off answer to either cover up a design fault or a "we can't be bothered ot look at this problem any more"?
Thanks in advance!
Thanks in advance!
