I have had a quick search but not really found an answer
Had a rather 'spirited' drive home yesterday and just pulling into the car park the temperature guage went to near 120 and the alarm went off.. The coolant was boiling and the fans werent on...
Anyway after playing with the fuses on the battery i got the fans on and left it cooling down for a bit.
Now i know i need a new fuse holder thing and am picking one up tomorrow hopefully. The fuse had melted before but now the holder is looking a bit melted
But today when driving the car from cold it started to overheat after only about half a mile.. It normally isnt even registering a temperature at this stage :S
Im not sure whats going on with the fusebox as the right fuse is doing some cooling but isnt getting the fans on.... Its not nice getting to work hearing the water boiling
Anyway was just wondering why it could be heating up so quick ? Is it likely to be a leak or split or something ? Someone suggested thermostat but after a short drive to work (ok probably no fans) the water was boiling...
Could this be caused by a dodgy fusebox ? Im really hoping when i change that its going to be all ok..
Was too scared to drive it home from work in the end so left it there Managed to borrow a massive vectra though so not all bad!
Any advice, comments and suggestions welcomed
