Where does it go?!
One for the morning.
Where is that pipe supposed to go? i know where mine goes, but where does yours go? the one above the dip stick. thanks
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
OK mate, I've just had a loko for you where that pipe goes. Basically it plugs into the pipe that runs under the black cover thingy shown on the left of the first photo. You'll have to unscrew the red plastic cover first (3 Allen bolts I think), then you can get access to the two philips screws that hold the black cover in place. Once you take that of, you should see that your little 5mm diameter pipe plugs into the big (20mm pipe) at 90 degree angle via a T-piece. Well at least that's how it feels.
Hope this helps
Mig
