Been toying with the idea of fitting the above and at last i have, and my god it wasnt as bad as what you think when you get a few decent people to help (you know who you are)
Here's some pictures and the route of the vac cable etc and some questions!!
This is the route i took for the cables to go onto the car through the bulkhead
I thought this might be a good idea as to avoid all the heat issues with turbo etc just drilled a small hole and came out of side!!
Picture of it all fitted, will do night pics tonight!! obviously
And you can see them in daylight quite nicely!
This is my question on the oil temp gauge there is 3 wires red, black, and green, now i have earthed the black one so what now with the red and green anyone?? both gauges light up well when ignition is on and dim also etc just these last 2 wires are bugging me, and also on the oil sender there is also 2 wires a black and a white as you'll see, any ideas would be really grateful!!
Took for test drive and boost gauge works nicely, peaked at about 16psi or so and leveled out at about 13-14psi which i think is normal considering what i have seen!!
