CD changer in Mk4 glove box
joonspoon
175hp. 275lbs/ft.
Nov 18, 2006
361
Oxfordshire
CD changer in Mk4 Ibiza glove box
This is how I did mine.
I'm not responsible if you wreck the car you are working on!
I've fitted my VAG CD changer in my glove box and thought this might help if you're doing something similar.
The cable I used is part number 1M2 971 735. About £21.00 from a dealer.
This is the panel in the back of the glove box you need to remove.
DO NOT PUSH IT OUT!
Use a sharp knife to cut the panel out
Panel removed.
Pull out the head unit.
I used these from Halfords. £3.99! :coolthumb
Feed the changer cable through the hole at the back & slide the changer into place.
Connect the leads up (only go one way :D ) and route the head unit end of the cable through to the back of the head unit.
Push the connection into the back of the head unit
Before inserting the changer connection.
After inserting the changer connection.
Push the head unit back into place.
Changer in place.
Hope this helps someone.
Guy.
Dude_200
Thanks!!
This thread reli reli helped, i was completely stuck on how to get the radio out lol .....yes its my first time doing anything like this. thanks!
~Divine~Wind~
Newbie Owner
Sep 6, 2011
74
Recently changed my head unit, unfortunatley it seems to have been removed before and the retention clips were knackered, took some getting out lol, smashed the scan button :(
hutchy44
did you happem to notice if there is an aux input connector in the back of the unit? mine hasnt worked since i bought the car and was wondering if the head unit had been changed and then put back in?
